ianmac23's avatar
ianmac23
Mounting a LCD TV on the wall
Hello
I have a 2010 Keystone Passport and I was wondering if anyone has mounted a TV on the wall. I would like to mount one on the back wall for the rear bunks. Has anyone done it and how did you find something to screw into?
Thanks for the help
Ian
  • RoyB's avatar
    RoyB
    Explorer II
    I certainly take my OFF-ROAD POPUP off the major roads... One of my favorite spots up on the George Washington right on the VA/WVA mtn state line is fed by a forest service road and then I go a few hundred feet beyond that. Actually cross a rocky mtn stream with my truck and POPUP. Granted my trailer doesn't have any high walls on it. My other trailers I have worked with for outfitting off-road communication projects certainly have the thin walls and they are still doing just fine as well...
    Here is photo of the mtn stream I have to cross to get the high point i like to setup my communications at using my POPUP trailer.... This is near a spot commonly called FLAGPOLE KNOB.
    No prob Cincygus - It justs reminds me I should put more disclosure info in my posts I guess...
    I certainly would not mount something that weighed 50 lbs plus using just MOLY BOLTS. The trick I have learned is to spread out the weight limits over a larger area. I used to use the spring loaded wing bolts alot but every time you remove the screw from them the spring nut would fall behind the wall. The MOLLY BOLTs are locked into position after they spread out behind the wall... You can remove the screw and the MOLLY BOLT stays in place. Pretty strong stuff for me to use.
    Roy Ken
  • ianmac23 wrote:
    Sorry I did not say this before I wanted to mount it inside and the wall does not say mount LCD here. Which is weird because it has all of the hookups there for power and TV. There is a LCD mounted in the living room which is the TV that I wanted to use. I think it is 26 inch. I wanted to replace the one in the living room for something bigger with a better picture and viewing angles.
    Well, maybe it did before and it was taken off. Get a stud finder - they are easy to use. I was scared to drill into the walls of my new TT to, but I wanted the LCD TV hung on the wall, so I got over it.
