kohldad
Jan 03, 2021Explorer III
Why not just take the cover off and then use square u-bolts to clamp them to the struts. Don't over tighten or the bolts could pull through the plastic. One bolt per light should do the trick. A little bit of RTV or rubber gasket under a washer under the nut should provide plenty of seal.
