JCR-1's avatar
JCR-1
Mounting Generator on rear end
I have a light 21 foot trailer and use a 3100 champion generator for A/C. My question is I would like to mount the genny on the rear bumper with some brackets however the rear bumper is only attached (welded)to each end of the frame with nothing in the middle . I would need to gain more support from the chassis frame i would think. Although I weigh over 200 pounds the bumper does support my weight without bending. I am wondering if I could weld on some angle brackets to the bumper. Seeking thoughts , ideas..Thanks
  • There are MANY reports of people dragging everything from bikes to generators down the road by one bumper weld or a security cable because they tried mounting carriers to a standard square RV bumper ("bumper" is really a misnomer - they should just call them sewer hose carriers). Take, at a minimum, Don's advice and have a fabricator weld up something strong to the frame. I would also share others' concerns regarding the load and balance issues with such a small trailer.
    On a personal note, I wouldn't want to be near you in a campground while you use a Champion 3100 to run your AC. I hope you are talking about private land or BLM/dispersed camping.
    Rob
  • I had to go back and read some of your previous posts to figure out what kind of camper you have. In a previous post you said you have a Coachmen Clipper 17RD (For visual, Click here.)
    It's a single axle trailer, which means any weight you add on the back will be noticeable on the tongue. But maybe the trailer is still heavy enough on the tongue, this will not be any issue. Still, this would be my first concern. When the tongue is light, the trailer will get bad sway. But you won't know until you try and see how the extra weight on the back handles.
    Next, looking at the many photos on the Google search, it looks like your bumper is a traditional 4 inch metal bumper welded in 2 places to hold it on.
    Carefully look at the actual welds and see if the weld runs the entire length of the connecting points, or if it is just spot welded. If spot welded, the bumper will not hold anything but itself. I'd even remove the spare tire in that case.
    If the weld is solid along the seam, it will be a much stronger weld and you may have a good chance at success. However, there have been stories of bumpers falling off due to too much weight and inadequate welds. Definitely re-inforce the bumper with additional support before you try adding the extra weight. If it's originally spot welded, have it welded completely. That's an absolute given, must do!
    One thing you have to remember, the bumper may be able to support your 200 pounds by simply standing on it. But, if you start jumping up and down on it, what happens then? When driving down the road, the rear of the trailer extends beyond the axle several feet. In the middle of the trailer, bouncing may be only a couple inches. But extend that to back, and the bumper may be moving up and down, being jerked 6 inches to a foot. And the harder the "hit" the more force there is on that bumper. Add additional length and leverage with the carrier hanging on the bumper AND the weight of the generator, and a simple 1 inch bump in the road (could) cause a couple thousand pounds of force bouncing up and down on that bumper.
    Bottom line.... yes! Get it strengthened and give it a try. If tongue weight is reduced too much, shift weight inside the camper to compensate.
    If it were mine, and I wanted the generator, I'd do the extra welding and support in a heart beat!
  • Hi,
    You will need to beef up the connection to the frame. I suggest using twin two inch receivers. That will prevent the generator from flopping from side to side.
    I deliberately offset the generator to the passengers side as I was too heavy on the driver's side.
    Be sure to not make the tongue weight too low.
    Bad idea, especially on such a short trailer ... aside from issues of how secure this may be the fact is you'll be significantly unloading the trailer tongue. JMO, but I wouldn't do it.
