DieselBurps
Sep 02, 2015Explorer
Mounting roof rack on camper
I picked up a Maggie rack by Topline MFG. I am wondering if I should use the hardware that came with it to mount it or if I should go another route? I have a Northstar Adventurer so its a wood framed camper. The hardware consists of T nuts basically an insert that gets glued in with RTV after the holes for the feet have been drilled. Should I use these inserts? I also have some 3m 4200 adhesive I can also put on the feet/pods.
Need some suggestions, would like to only drill once!
