towpro's avatar
towpro
mounting solar with screws.
has anybody ever had to remove a solar panel? The ones I bought use 4 Z brackets. a bolt comes though bottom of solar frame, than through Z bracket. once z bracket is mounted to roof, the only way to get panel off is to cut the seal and unscrew the Z brackets from roof.
I can't drill hoes into side of panel for mounts as it will void warranty.
But besides a broken panel, why would I need to remove them?
I can use a chimney nut, that slides on panel frame and clips in hole, than put a bolt up though bottom of Z bracket into frame, but I fear that the hidden chimney nuts could rust out and give way with wind pressure when I am going down the road (I do camp in salt air a lot).
even with this chimney nut, I only have 5/8" inch between bottom of bracket and roof if I did need to remove the bolts.
I am over thinking this right? just bolt bracket to frame, test everything out, than screw and seal it down?
Than just keep the chunks of debris out from between the panel and roof (dead leaves, etc). When washing roof just get in as far as you can with a brush.
  • I thought of that kind of mount system but I am trying to keep mine as flush as I can to roof. RV's stand a very high chance of catching a tree limb. Even a small limb can under the panel it has a chance of doing more damage than if I can just deflect it over the panel.
    sometimes I think about making a leading edge with a air foil design to close the gap between roof and panel in front, but that again would take another hole in side of panel frame.
    Just my thoughts on it.
  • RoyB's avatar
    RoyB
    Explorer III
    I'm thinking to use the aluminum UNISTRUT stock on the roof edge where I can screw down in some wood side edges and use the panel Z angle to bolt to the panel and the Unistrut.
    This is how UNISTRUT is used...
    Google Image
    The Unistrut will allow me to slide the panel ON and OFF as needed and not put a hole in the roof except on the very edge of the roof. I could probably only drill into the side of the panel up near the roof just as easy using a L bracket for the Unistrut going across the roof.... I already have a few things mounted to my roof side panels...
    An installed solar panel would look something like this perhaps...
    Google Image
    Haven't checked into the cost of these UNISTRUT units yet.. probably high dollar stuff...
    Roy Ken
  • I used the same Z brackets and bolted them to the panels and screwed them to the roof. My only problem was that the wires were under the panel and me fingers would not reach them. A coat hanger get them out. Project done.
  • thanks for the reality check :). heading to garage to put stock mounts on with nuts and bolts.
  • A TC is probably the better place to use them since it's unlikely to tilt. I doubt very much that you will ever have a problem with the panel itself. More likely might be the connections on the rear of the panel. If the cover is removable or if you have to attach the wires to the panel box, be sure to use electrical grease in there. I would never put anything up there that isn't aluminum or stainless. There are better grades of stainless too.
    With the low panel prices I would guess that it's going to be borderline worth while years from now to even use the warr when shipping prices keep going up and panel prices keep going down. I drilled holes in all my panels for rivenuts and tilting. If tilting is practical and you need the increased performance, tilting does help a good deal. I have never run into anyone who has replaced a panel and I often run into people with very old panels.
  • Yes. Broke panel.
    But generally unless broke, need would be very rare. Roof replacement, or refitting another panel, changing layout? Cant see a reason.
    Unless new replacement identical, unlikely, mounts probably need relocation anyway.
    So I wouldn't make allowance they could be reused, mount like its going to be there forever...
    IMO Yes.
    I also added blue loctite to the screws that mount the z clips to the panels just to be sure they don't rattle loose.
