hbrady
Mar 07, 2016Explorer
Mouse nest in heat duct
This past fall I sealed up all entry points to my Freedom Express TT with Great Stuff but mice still got it. Once I discovered droppings I installed a barrel trap which worked well but apparently the damage had been done. I uncovered the trailer yesterday, put battery in, hooked up shore power and decided to fire up the furnace while I was working inside. As soon as the blower came on I heard a slight thump and after the heat was on for a few minutes I noticed the unmistakable odor of a burning mouse nest. I checked the outlets and of the three, one had just a slight trickle of air coming out. I ran out of daylight before I could dig too deep but my theory is, mice got into the heat duct hose through the round outlet cover (no screen) or they chewed through the hose somewhere. The slight thump I heard was the nest material being pushed against the outlet cover.
I plan to start pulling everything apart next weekend but I had a question. My furnace is located either under the fridge or under the dinette seat, not sure which but I'd like to inspect everything while I troubleshoot the issue. Would this access panel be for the furnace or the fridge? The exhaust under it is the furnace exhaust so I'm guessing this is to access the burner for the fridge? What I don't know is how those fasteners work. They are slotted but I'm not sure if you turn them or squeeze them and pull.
