Timtation
Dec 09, 2014Explorer
Mount the caster wheel to the post, carry a 2'X4'X1/2" sheet of plywood in the tv. Put the plywood down under the tongue post and you will be able to move the tongue as needed. You may need to rotate the trailer wheel (the axle wheel, you move them,rotate, it is much easier than pushing the tongue or traier) to position the tongue if things are not optimum. If you start doing this at the beginning of the season by the time the plywood has splintered to 8"X2' you will no longer need it.
44,068 PostsLatest Activity: Jun 01, 2026
