stevehaslet's avatar
stevehaslet
Moving a truck camper. just 10 feet
Hello,
Im fairly new to the truck camper. I have a Lance Squirelite 195. It has a 9'6" floor. I'm trying to store the camper in my drive way but due to an overhanging roof eave I cant get it where I need to put it. The camper is on a F350 dually. Im thinking that if I can somehow lower the camper I can get it under the eave. I've seen dollies that can do that but I really dont want to buy a dolly. Thats probably a $1300 investment. Im wondering if I could rent a utility trailer. Put the camper on its legs, pull the truck out, slide a 6 foot wide utility trailer (rental) under the camper. Lower the camper on to the trailer which should get me below the eave. Then I can move the trailer back and Im where I need to be. Thoughts..Comments..
My big concern is the weight of the camper. I believe that to be around 3000 pounds. Can the utility trailer hold that?
  • Most heavy duty single axle trailers can handle 3,000, although they will have a gross weight rating of 2,900 pounds due to not having trailer brakes. A tandem axle utility trailer with trailer brakes will have a higher weight rating. Just don't use one of the light weight landscaping trailers. If the camper fits on the trailer my concern would be the support legs on the camper. You will have to have the trailer bed high enough so the camper supports are off the ground.
