westend
Nov 04, 2016Explorer
Moving the water tank to the rear would be ill advised. If you could easily move it to a location directly on the axles or adjacent in front it may help the overall load carrying aspect with the filled tank.
IMO, it's a lot of work for a fairly nebulous goal. All of the exterior fittings will have to be relocated and the supply line changed along with some supply plumbing (maybe). The drains may have to be moved, also. The end result may effect the handling of the trailer since I don't know the engineering of the original.
