mbloof
Dec 24, 2014Explorer
chuckklr04 wrote:
I'll be working as an Core extra for the TV series Salem season 2. Hours will be long, 12-15 or even more 3-5 days a weeks. Figure I'll have just enough time to sleep during the work week.
They do have showers, bathrooms on set. so I plan on doing that there. should be no cooking needed during the work week. Meals are provided.
Gonna try real hard to avoid the campgrounds fees the during the first two weeks jan 15th-31. Then perhaps pay the 350 month for the nearest one.
So in a nutshell, unless the lot has 120VAC or you have a large enough portable generator, the AC won't be used.
Depending on outside/inside temperatures you main power usage will be:
- heat (furnace)/Cooling (Fantastic Fan)
- lighting (LED light fixtures help TONS here)
- TV/Radio/Entertainment (laptop, exc.)
- Water pump+on board electronics
Given the long work days I'll guess the "awake time" spent in the camper during the week will be rather short - 1-2hrs in the AM/PM to get ready for work and wind down from work - so unless you like to fall asleep with the fan/furnace and/or lights on your realistic daily heavy energy use will be limited to ~2-4hrs.
I've regularly camped for a week with ~100w solar (50% shade), 120AH of battery capacity and 2x20 propane bottles.
If your host truck is wired well enough to charge the battery it can be used in a pinch to help charge your battery, the smaller Yamaha/Honda 1000w inverter/generators work well for this to. (and cost much less than the 2000w units)
A small camper may only have 1 propane bottle which ought to keep the stove top and refridge going for a week or more.
It all comes down to managing the amount of daily power you use and then replacing it every day. (in attempts to keep the charge level above (ideally 75% to 50%). Then again, a 100-120AH deep cycle battery costs a whole whooping ~$75 (or less) at Costco.
44,025 PostsLatest Activity: Feb 18, 2025
