afidel
Apr 02, 2019Explorer II
Gdetrailer wrote:Ralph Cramden wrote:Shawfamily6 wrote:
It was pretty windy and raining that day. The next day we got closer to 7.5. I have seen a few of you mention different gears. Should we be pulling in something other than automatic? I think I might be confused. I know you can take it out of automatic, is that what we should do and put it in a different gear? If so, what gear do you recommend? Sorry if that is a silly question! Thanks for all the help!
If your not in rolling hill country or stop and go traffic, with a 7500 lb trailer behind a 6.0 GM 2500 take it out of tow/haul. Don't use the tow/haul on an interstate or other 4 lane highway. Its not needed and is probably what shot your mpg in the foot. Leave it in D and drive it. When you get in hill country or stop and go traffic kick in the tow /haul, take it out of D, and shift manually. Drive it like you stole it. Wind it up to 4500/5000 rpm. It really sounds good up there.
The owners manual will tell you what conditions to use the tow / haul button and trying to get the most mpg is not one of them. It won't hurt the truck whether or not you use the tow / haul button, or if you have it in D or shift it manually with the rocker switch. Those trucks are made to tow and haul. 7500 lbs behind one is an easy day for the truck.
Hmm.. I guess I don't think I would ever like to own a Chevy if Tow/Haul "affects" mileage..
I am thinking Chevy follows a similar pattern like Ford, Tow/Haul mode MODIFIES the shifting pattern/strategy to TAKE BETTER ADVANTAGE of the engines torque. This often means holding a gear a bit longer to get into the sweet spot on the RPM essentially delaying upshift or downshift.
On Ford, tow/haul ALSO adds in AUTOMATIC DOWNSHIFT strategy for better control of your vehicle speed when descending hills or even stopping at traffic lights or even sudden maneuvers which require faster stopping. It assists you..
If GMs does not do that then why even put that feature on the vehicle???
I would suggest READING THE MANUAL on what Tow/haul does for YOUR VEHICLE, then FOLLOW THE MANUAL rather than arm chair QBs behind the keyboard..
I enable Tow/Haul EVERY TIME I hitch up or even put a huge load of cement blocks in the back of my Ford, my Tow/haul has never hurt my mileage, in fact it seems to HELP the mileage while towing or hauling..
The other thing that tow/haul does is engage the torque converter at a lower RPM which leads to lower transmission temperatures, that can be very important in some situations.
44,065 PostsLatest Activity: Apr 14, 2026
