enblethen
Jun 19, 2014Nomad
This is what Bumpy suggests used in conjunction with a hockey puck style adapter. Plug it into the 30 amp receptacle. Not only does it check for voltage and polarity but checks for other wiring issues you could find in the pedestal or the campground electrical systems. It is a little safer to use then a meter.
Electrical meter
Voltage should not be less than 110. Some items will work down to around 105, but could cause damage. I would not like to see over 130 volts without any loads.
Electrical meter
44,071 PostsLatest Activity: Aug 30, 2026
