ItsMeCarlos
Aug 24, 2019Explorer
Multiple Tire Blowouts
Hi all!
Noobie to the forum but have been lurking for a while.
Thanks for all the info you all share in this forum. It helps a lot more people that you know.
So I have an issue....
We own a 2017 Forest River Salem 30KQBSS TT. This is our first RV and we love it.
We usually just go up the road to Orlando maybe 2-3 times a year. This is just shy of 400 miles round trip.
During the summer of 2018, we make our 4th trip to Orlando and we get our first blowout on the passenger side. These were the original factory tires (I do not have the tire info on hand). The tires probably had around 1400 miles on them.
A little bit of background, I am very meticulous when it come to towing safety. I have towed in the past. I check all air pressures, inspect all tires, grease, lube, etc, etc... The tires looked in good shape.
Back to the blowout, I change the tire and I see the tire behind it (non blowout) has some of the steel threads embedded in it from the blowout tire.
I decided to change it out also as a safety precaution. Luckily I carry two spares.
It caused a lot of undercarriage damage as well as fender damage but I was able to duct tape and tie wrap everything so I can get back on the road. It was a mess.
We get to our destination and had roadside come and replace one of the tires since I now had no spare.
So now I had one spare tire on (can't remember the make), one new tire that roadside installed and the two original tires that came with the TT.
Made it home with no issues.
Before our next trip I installed two new tires. This time I purchased Load Range E tires. Originally all the tires before were Load Range D tires so I figured I would go with a higher range tire.
All my tires up to that point were Load Range D as per the manufactures recommendations.
I install my 2 new E tires (1 on front passenger, 1 on front driver) and I install my newer tire (roadside assistance replacement) as well as my newest spare tire.
Fast forward to this July 2019 (6th trip). This would be our second trip since our last blowout (about 500 miles on the new tires). One hour into our trip we get a blowout on the drivers side, rear tire. This was a load D tire. I replace it with one of my spares (Load D). It was another mess but got back on the road and finally made it to Orlando from Ft. Lauderdale.
Same trip driving back home (remember, this is a 200 mile trip one way), I get a low air pressure reading from my new wireless TMPS system I had purchased before our trip. On a side note I highly recommend one of these. It gave me peace of mind.
I pull over and sure enough as the TMPS said my passenger side rear wheel was way low on air and it was (air leak). This tire was also a Load D tire. Down to my 2nd and last spare, I change it out. This tire is also Load D.
Get back on the road.
About an hour later BOOM! Tire I just replaced blows out! @!%#%
Luckily it happened next to the rest area.
With no spare tires left, I call a local, mobile tire repair shop.
While I was waiting for him I'm trying to figure, 1. What the heck is going on. 2. I still will not have a spare if it happens again.
I called the tire guy before he got there and I told him to bring me two tires.
Gentleman comes out and replaces the blowout and the last remaining Load D tire with a Load E as per his recommendations.
A couple of hours later we (wife, our two kids and our dog) get back on the road. We made it home with no more issues.
Any ideas what can be happening?
I'm thinking of weight issues, so I looked at the manufactures weight and tire info on the trailer.
The GVWR is 9699 lbs.
On the tire and loading information sticker, it says " The combination weight of Cargo should Never Exceed 2731 lbs."
There is another yellow sticker that is labeled Recreational Vehicle Trailer Cargo Carrying Capacity that states the same thing. "The weight of the cargo should never exceeded 2731 lbs."
So am I missing something?
There is no way I am carrying more that 2,700 lbs of stuff in my trailer. Clothes and food for 7 days, games and the kids scooters, etc should be no where near that. I know, I should take the trailer to a local scale to know for sure.
So if by the manufactures numbers, GVWR 9699 lbs. plus Cargo 2731 lbs. totaling 12.430 lbs. can be safely towed.
Now here is the kicker, the tires that came with the trailer and the tires that are recommended from factory are Load Range D tires. Load range D tires have a max load 2540 lbs. per tire. My trailer is a dual axle (4 tires), so the total of the max weight for the tires should be 10,160 lbs. This is almost the weight of the TT without anything in it!!!
As per the TT label I should be able to load another 2700 lbs but there is no way these factory tires are manufactured to hold this.
So, am I missing something?
Am I reading the label wrong?
Did the manufacture mess something up?
Six tires on a two and a half year old TT with around 2700 miles.
I am in the process of contacting Forest River but I wanted to get some advice before I do.
Sorry for the long read.
I look forward to hearing your replies.
Thank you in advance!
Carlos
Carlos
