2112 wrote:
Mike134 wrote:
Johnny Hurryup wrote:
I bought this truck a few months ago. It has the trailer hitch 7 pin connector and on the dash, a screen for towing info. But it has no brake controller with some kind of gain control. I'm shopping for a travel trailer. What do I need?
I recommend the Ford integrated brake controller.
You'll find this forum advise seems to limit a F150 to 6000lbs the F150 forum folks are comfortable up to 8000lbs.
here's a link to get you started
https://www.f150forum.com/f118/adding-trailer-brake-controller-483714/
The real confusion is the fact that all F-150's are not built the same. You can't say you have an F-150, so you are good up to xxxxlbs. My previous 2005 F-150 was max'ed out towing a 6000lb TT. My current 2011 tows a 10,000lb FW very comfortably. This FW would have crushed the 2005's rear axle and smoked the tranny. You have to know your numbers.
Yes, I know my 2011 is a rare bird but I'm using this as an exaggerated example. Point is, F-150's have a wide range of spec's. You need to know your specific trucks specifications to determine what you can tow.
I agree but to my point there's a thread on this forum where they asked if it should be a 1/2T or 3/4T The weight police recommend a 1ton "just in case" For the trailer they were speaking about a 1/2T would be just fine.
