mrekim wrote:
Did you then use expanding foam to seal everything back up?
I only used the foam where I had a pipe etc that creates an air space. I am using Reflectix insulation on the inside of the cover and hem the seams by the wheels so water does not work its way into the Reflectix.
The Coroplast cover them compresses the Reflectix on the frame mount to make an effective enough seal.
If I was to use the foam along the entire perimeter I was afraid I would almost destroy Corplast if I ever wanted to get it off to service the under side of the camper. My slide drive motor is in there and the holding tanks.
