JBarca wrote:
Taped over edge to create a hem seal then put both up onto the bottom of the camper.
OK, I guess I was a little confused. I thought you only "hemmed" the area by the tires. I was wondering if you just depended on compression for the rest.
JBarca wrote:
LOL.... I was shocked the radiant heat off the ducts actually was that warm. In my case the furnace has to run when cold weather (below freezing) camping or the tank compartment will not be indirectly heated.
WOW
Is that the only under floor duct - maybe not insulated on purpose?
