mrekim wrote:
JBarca wrote:
Taped over edge to create a hem seal then put both up onto the bottom of the camper.
OK, I guess I was a little confused. I thought you only "hemmed" the area by the tires. I was wondering if you just depended on compression for the rest.
Sorry, need to clarify. I did the entire wheel well area as even the coroplast would get water in the flutes. In my case there this is about ~ 6 feet that is fully taped by the wheels. The other areas I just used ~ 6" long strips to hold the Reflectix to the coroplast to get it up. I have no water concerns in these areas and the sandwich compresses enough to not be a problem.
