SoundGuy
Sep 23, 2016Explorer
freymann wrote:
I have watched quite a few videos on the Sway Pro, including that one. Both before and after purchase.
My bars do not go on/off that easily AT ALL. EVER!
I have complained about this from day one.
This in itself would suggest your Sway Pro isn't correctly set up so since you've watched "quite a few videos on the Sway Pro" the question then is whether you've yet taken your trailer to a lot where you can properly level it and go through the setup procedure yourself. :@ Obviously no system regardless of what it is will work properly if not correctly set up as recommended by the manufacturer. Since it appears you may be able to have your friend who successfully tows with a Sway Pro take a look at yours checking the installation setup would seem to be your next logical step.
44,068 PostsLatest Activity: Jun 10, 2026
