CavemanCharlie wrote:
Growing up on the farm my dad would yell at me if he saw me backing up a trailer by looking out the side window. He insisted I use my mirrors only. I still don't do it that way religiously but, the practice was good.
Yes! Actually, in many states you will fail your commercial driver's license test if you look over your shoulder. Learn to use your side mirrors, understand what they are showing you.
As to someone helping... I make sure that if someone is helping me back in, they ONLY tell me which way the rear of the trailer should go. If they start trying to tell me which way to turn the truck, things just get confused quickly.
As to hitches - different hitches don't really change backing in (although I've never used or even seen a "Pullrite" hitch), BUT remember to disconnect sway control bars. Sometimes backing into tight campgrounds can mean almost jackknifing the trailer, which can bend a sway control bar. Also, depending on your setup, it may be easier to disconnect weight distributing bars before backing, in case when you are done the truck is at an odd angle to the trailer.
Practice, practice, practice!
