toddb
Sep 07, 2019Explorer
Sorry about the pictures, when I used an IMG tag they didn't work.
The compressor is Sikelan, secom knock off I guess. All the electronics stay. I get an AC failure though so I'll see if I can bypass that later.
I think the temp stall at 43 was due to the large temp delta with the outside temp so high, the comressor didn't cycle until I changed the temp setting. I didn't have the coach AC on. The evap temp was 35* with the IR gun.
I dislike the condenser fan, the mount blocks the fins and it makes a lot of noise. A better shroud would most likely reject more heat/lower the pressure and reduce compressor draw.
44,071 PostsLatest Activity: Aug 30, 2026
