JimK-NY
Sep 08, 2019Explorer II
StirCrazy wrote:SidecarFlip wrote:
The one I'm looking at, max draw is 6.5 amps at 100% duty cycle but less than 1.2 amps cycling.
is there any stats on how many Ah one of these fridges would draw over a 24 hour period? would be nice to see something say at a 40 degree cabnet temp in 90 degree weather parked in the sun it used so many Ah.
Steve
I have a small (4 cu ft) NovaKool with a Danfoss compressor. When the ambient temp is around 70 degrees or less it does a great job pull 2-3 amps with about a 1/3 duty cycle. That is about 20 or so AH per day. When the temps increase to the upper 80s or 90 degrees, the unit runs almost continuously. It keeps internal temp pretty well but chews up 60-75 AH per day. My solar system has 300 AH of AGM batteries so I am good for only 2 days in the shade or 2 days of clouds. Even with full summer sun my panels are not big enough to replenish the system with a full day of charging. Compressor refrigerators definitely have a downside.
44,071 PostsLatest Activity: Aug 30, 2026
