ShinerBock wrote:
And you are confusing how a gas engine operates with a diesel. Two different things. Gas engines have to stay within a certain air/fuel ratio(roughly 14.7:1 +/-3 parts air) meaning the more air you add, the more fuel you must add. Turbos do slightly improve a gas engine's thermal efficiency
Diesels can operate at a much wider air/fuel ratio from as low as 14.5:1 all the way up to 80:1 or even 100:1 depending on the engine. An N/A diesel does not have the ability to run that lean because it cannot suck enough air for the fuel being added as with any engine that operating at low rpms. Adding a turbo allows the engine to increase the amount of air to the same parts fuel making more power with the same amount of fuel. Turbos also increase a diesels thermal efficiency even more than a gas engine.
All three half ton 3.0L diesels don't just produce the same power as an old N/A HD diesel it exceeds it by at least 50 or hp and over 100 lb-ft all while using less fuel. Hell, even my 2.0 liter turbo diesel in my car makes more power and torque than the old Ford 6.9L and 7.3L N/A diesels.
I am not believing you on your brother in law story. So you are telling me that you two filled up and followed each other for a whole tank and refilled up again just to record each others mileage? And that a 2008(with emissions) truck weigh's within a couple hundred pounds of an old N/A engine truck? I am more surprised that you were actually were able to keep up with him in an old N/A diesel. I remember driving my grandfather's 185hp/338lb-ft 7.3L IDI, and it could even get out of its own way let alone keep up with a 350+hp/600+lb-ft 2008 turbo-diesel.
Unless you are pushing the engine outside it's normal operating ranges...they both are burning all the fuel that goes in. Once all the fuel is burnt, adding more air does not improve the efficiency.
You still seem to be confusing HP production with efficiency.
...and, no problem running at around 70mph on the freeway with the old 7.3. We weren't drag racing. Michigan to Arizona...And he owned the old truck before I bought it off him and he said he got similar MPG, so it's not the driver.
