valhalla360 wrote:
You are confusing the ability to generate more HP with fuel efficiency.
Sure a modern 3.0l turbo diesel can produce the power of a bigger NA diesel...but it uses pretty much the same fuel when both engines are producing identical power. As long as the engines are within normal operating ranges, power is largely a function of HP output.
As far as comparing to my brother-in-law, that was based on following him, so similar speeds and driving pattern. The trucks are within a couple hundred pounds. So no, being turbo doesn't automatically result in better efficiency.
And you are confusing how a gas engine operates with a diesel. Two different things. Gas engines have to stay within a certain air/fuel ratio(roughly 14.7:1 +/-3 parts air) meaning the more air you add, the more fuel you must add. Turbos do slightly improve a gas engine's thermal efficiency
Diesels can operate at a much wider air/fuel ratio from as low as 14.5:1 all the way up to 80:1 or even 100:1 depending on the engine. An N/A diesel does not have the ability to run that lean because it cannot suck enough air for the fuel being added as with any engine that operating at low rpms. Adding a turbo allows the engine to increase the amount of air to the same parts fuel making more power with the same amount of fuel. Turbos also increase a diesels thermal efficiency even more than a gas engine.
All three half ton 3.0L diesels don't just produce the same power as an old N/A HD diesel it exceeds it by at least 50 or hp and over 100 lb-ft all while using less fuel. Hell, even my 2.0 liter turbo diesel in my car makes more power and torque than the old Ford 6.9L and 7.3L N/A diesels.
I am not believing you on your brother in law story. So you are telling me that you two filled up and followed each other for a whole tank and refilled up again just to record each others mileage? And that a 2008(with emissions) truck weigh's within a couple hundred pounds of an old N/A engine truck? I am more surprised that you were actually were able to keep up with him in an old N/A diesel. I remember driving my grandfather's 185hp/338lb-ft 7.3L IDI, and it could even get out of its own way let alone keep up with a 350+hp/600+lb-ft 2008 turbo-diesel.
