hedge
Jan 12, 2015Explorer
hmm, not sure on that one. It sounds like your tv connection port is different than mine. I'm not sure if you could use a combiner or if the signals would interfere. Just off the top of my head i'd probably use a coax switch mounted in the cupboard but then you'd have to flip the switch to the source you wanted. I'm not sure how these things are usually wired up, hopefully someone else will come along with a better solution.
Coax Switch
Coax Switch
