retiredgeologis's avatar
Sep 01, 2022
My new race car alternator for LiFePO4 batt bank
Added 4 100ah LiFePO4 in parallel to my TC. Truck is 94 Ford F-350 XLT crew-cab IDI 7.3 L diesel dually. Understand that these suck up juice so fast that ordinary alternator will burn out with this high draw. What to do?
Other folks have this problem. Race cars, off road vehicles with banks of lights for night desert runs and ambulances with lots of medical equipment. Several manufacturers make high output alternators for this purpose. I checked with PowerMaster and Summit Racing who both said they had model to fit my truck and that it could handle the new battery bank. They have alternators for pretty much any year or model truck.
Original alternator was 90 or 110amps. Not many amps needed back in the day, plus this one was at least 12 years old, so time to replace it anyway. Cost for high output alt is double at around $300 vs 150$. Alt delivered and note inside said it had been measured at 207 amp output. local garage installed it with no problems.
Know that there are several ways to address problem, dc to dc etct To me they seem to restrict charging speed which is big advantage to these batts. Will this work? It should. Will find out. If I wind up on the side of the road I will let you know. Will be far from the bigger mistakes I have made in my 66 years.
  • With high output race car alternator you do not need to be worried about too much output from it because that is what it is designed for. Will not burn out. Cannot overcharge and harm batt bank because the BMS(Battery Management System) stopes the alt from overcharging of the battery bank. Simple. Gives you the fastest charge available. DC to DC is useless and just slows down your charging.
  • If the wire is good those 4x LFP could absorb 400+ amps. What is really needed is an alternator that will limit amps and allow the voltage to sag and match the battery much like a standard battery charger. Balmer and Victron have regulators for the boating world that will actually limit the amps.
  • Simple. Install a DC/DC charger in the alternator charge line to your rv battery bank. Victron makes a top notch one.
    P
