egarant
Jan 17, 2014Explorer III
My Timbren Review
Well I purchased a set a rear Timbrens for my truck. After one week of testing, I decided to return them, here is why.
Extremely easy install, that's a given.
They absolutely minimized the rocking back and forth when going into a driveway or my favorite, the gas station tank covers! My truck is a dually and I was still able to notice a big improvement is stability.
What I couldn't live with was the amount of bounce they introduced to the ride.
When you lower the jack after install, the Timbrens touch the top of the rear axle, then start to compress along with the rest of your suspension. What happens next is, what I believe is the root of the bounce.
At some point the Timbrens stop compressing, and so does the rest of your suspension. Now I know that without them installed, my leafs would normally compress further, but at this point the Timbrens have become THE major rear suspension component. The truck is now relying on the several inches of travel and compression that the Timbren allows for. I have to give them credit, they are tough little buggers to take on over 2 tons and keep bouncing along!
I did install the heavy duty model that was suggested for slide in camper use.
Interesting product that just didn't work out for me. I would though, recommend you trying them out and see if they work for you as they are very easy to install or remove.
Cheers!
Cheers!
