ruthiebaby88's avatar
ruthiebaby88
Narrowing it down...
So here are some campers I am trying to choose between - would love to hear any thoughts you have. My use will be boondocking in Idaho (or on occasional trips across USA) with 7 months summer, 5 months winter, probably 30 nights a year.
1. (5,000$) 2002 Lance 815 - My current fav! Wet wt only 1875# which will make finding a suitable truck much easier. The price is right and although it does look used inside, the only structural concern I have is the owner said they were afraid that the roof might develop a leak because they saw a pool of water on it and they were planning on getting everything resealed in spring.
The curtains in front of the pass through window had water marks as though water had seeped up from below - I did not see any water damage around the window though. Owner states window does not leak, thinks it may have been steam from when she was canning in there.
I will call a mobile RV mechanic and plan to ask for a prepurchase inspection.
2. (6,995$) 2000 Lance 880 - wet weight (2450#) 2 concerns -
A. panel under camper bathroom pulling away (underneath camper) - shined flash light inside but could not see what was going on in there - rodents? dry rot? or does the panel just need to be refasteded?
B. front pass through window - the 2 outer sections bow out - owner states they came that way and it just has rounded windows - however I have not noted this in any of the other Lance campers and they did not feel evenly round but a little wavy.
3. (13,000$) 2006 Northern Lite - Missoula (7hr drive) - Owner states this had some leaking around a window, but was professionally repaired.
  • Double check where the lance 1010 would sit in the trucks bed. If I remember correctly the lance 1010 model has a COG that's behind the rear axle and it effected the handling.
    I can remember reading some posts regarding this issue where one of the lance models was not the popular choice and the 1010 comes to mind.
    People really noticed the difference once they switched campers on the same truck.
  • You may have heard this from someone else but rather than starting a dozen threads in a short period of time, it would be more polite to run a general "looking to buy & outfit a TC, many questions" thread and just add your new questions to this. Running many threads at once is like hogging the conversation as it pushes other folks' recent post to the back pages. And it can have the opposite effect from what you desire as folks will see that you're flooding the forum and ignore your posts. One of those people may be just the person you needed to reach to answer a question.
    That said, welcome to the TC forum and I wish you luck in your search. From the one thread I did read, I think a TC will suit you fairly well. The friends will have to be very comfortable with you to travel together in a TC though :C
    Phyllis
  • If you have the truck to carry around 3,500-4,000# I would go with the Lance 1010. Should have aluminum roof which will hold up well to limb scraps, has a decent size wet bath.
    Second option would be the Northern Lite as it has better insulation, lighter and almost no overhang which is much better for exploring forest roads. Biggest problem I have with the model is the small bathroom.
    Just never been impressed with the Eagle Caps for the weight and price.
    Not sure why you didn't list it, but did you consider the Lance 915? Has the same bathroom as the 1010, almost as much as the 1010, without the overhang. Plus it should be several thousand less.
