kylekai wrote:
Bigimac wrote:
"As far as mats are concerned, I was also going to go this route until I read about using a 2" thick, 4x8 sheet of Owens Corning Rigid Foam Board Insulation. I cut it to the truck bed size and my TC rests perfectly on it. "
I never thought of rigid foam board insulation. I can get what I want for $16 at Home Depot. Are there disadvantages to rigid foam board insulation?
Yes you can distort the bottom of the camper because the heavier, stronger sides will dimple down into the rigid foam insulation while the middle can get pushed upward. Thus potentially damaging the camper bottom. Better to have flat strong platform with thinner truck bed mat and strips of plywood underneath.
