Jonnygsx
Mar 11, 2018Explorer
mkisamore wrote:
wanted to chime in here s bit i had a camplite 8.5 on a 2011 2500 hd and pulled an 18 foot enclosed trailer behind it. the camper weighed in at 1850 lbs . i also pulled a horse trailer behind with no problems. i did mount a hitch on the front of the truck to carry my generator when boon docking. i just recently moved up to the big guys with a new 2017 2500 hd duramax and a toy hauler. a 6.8 camplite and a 2500 should be a good combination as far as the bikes i reccomend a trailer ,reese makes a hitch extension that i used with my set up and worked well .can send you a picture of my old set up if you like
Maybe the old 8.5's were lighter, but the current weight of the 6.8 is 2000lbs, and the 8.5 is 2500lbs. And thats dry. So you had to be overloaded then right?
