GoPackGo's avatar
GoPackGo
Need a Tonneau Cover
Folks - I could REALLY use some help - I have a 2013 F350 Long Bed with a Hensley BD3 5th wheel hitch and a recently installed aux fuel tank in the bed. The hitch is lower then the top of the bed rails and the aux tank is about 1/2 inch lower then the top of the bed rails.
I would REALLY like to find a hard tonneau cover that will work but so far - no luck. The retractables all seem to require room at the front of the bed but there is none because of the tank. Looks like none of the covers will work that sit level with or below the bed rails. I have investigated Fold-A-Cover (sits above the rails) and even talked with their customer service. It will not work either because there is a bunch of hardware under the front panel that requires several inches of clearance.
Are there any others that could work ?
Or am I locked into getting a soft cover ?
Please understand that I have nothing against soft covers. I just want a hard cover from the security point of view. If a soft cover is my best option, then I just won't keep anything valuable in the bed.
Thanks very much.
Tim
