krobbe
Dec 15, 2016Explorer
The maximum trailer hitch weight capacity is less than the rating on the hitch receiver. The manual states 1200lbs max tongue weight most likely due to the P tires, coil springs and drive train limitations. The TT will most likely be at or over 8000lbs with a tongue weight of 1100 to 1300lbs. You're in 3/4 ton territory. That 5.3L is going to hate you for longer trips. I'm not saying you can't do this. I'm saying it'll be a struggle. I wouldn't try the cross country trip with this combo thru mountains.
Link to manual. page 4-53
The manual also states:
8800lb towing for the 4.10 axle ratio
7800lb for 3.73
6900lb for 3.42.
These are all things I considered and researched before buying my 3/4 ton Suburban.
By the way, the GM hitches of that generation truck are junk. Replace it with a Curt class V for a couple hundred bucks. Mine bolted on in under 20 minutes.
7800lb for 3.73
6900lb for 3.42.
