beast_3's avatar
beast_3
need advice on materials used in TT construction
My wife & I want to buy a TT, 25-30', maybe 1 slideout, for travel this summer. I've found many makers use similar floor plans in a wide range of prices. I've looked at several and researched far & wide, but find it hard to get accurate information for a TT made with the best basic materials, real plywood instead of OSB or particle board, Adzel walls instead of luan plywood, etc. Salesmen make widely inaccurate claims.
We had a 2nd hand class C that was OK until it developed a hidden leak and the exterior walls started delaminating and mildew set in.
So, has anyone any recommendations on a TT model without luan, OSB or particle board, the best insulation R ratings, welded instead of bolted chassis, and any other of the more desirable materials used in mid-priced travel trailers? I know Lance units are well made but they seem too expensive.
Any advice would be greatly appreciated.
Thanks!
Beast
  • All of the things on your wish list are all good things to have...but, unfortunately - they are found in the most expensive trailers...like the Lance you mentioned...
    (you get what you pay for and if you want it all, you are going to have pay for it.)
