jbjuices wrote:
I'm heart broken, but will probably have to forego the scooter. I would like to carry items on the back (i.e. wood, hose reels, etc) so I'll need to do some transferring of weight...just not sure if I can transfer that much. I'm taking the unit by the local RV place to see if my equal-I-zer hitch is at the max capacity. I'm just so bummed about this, but should've asked more questions.
Responses are spot on, but I think you're still confused. The hitch nor its capacity is not the problem.
By adding weight to the back of the TT, you actually removed weight from the hitch causing severe unbalance.
Even if you try to add 400lbs to the tongue to offset the Scooter, the excess weight being on the far extents of the trailer is no good for towing stability.
