Originalwingman's avatar
Apr 18, 2021
Need Advice
I purchased a 2010 F150 SuperCrew, that calculated to a payload of 1800 lbs.
I purchased a 2018 Travel Lite truck camper that was labeled at 1280 lbs.
I installed the Timken suspension enhancement system because the truck sagged when bringing the camper home.
With the camper and truck fully loaded with my wife, myself, full tank of gas, and all my gear, the truck is perfectly level front to back. No sagging, and seems to handle fine driving.
Now I’m scared because the Cat Scales show that my rear axle is overloaded by 1,140 lbs, and the gross vehicle weight is overloaded by 1,400 lbs.
Has anyone else been traveling with this high of a overloaded vehicle and been ok?
The guy I bought the camper from had the same truck as me and traveled from Michigan to Yellowstone and back without problems.
I need suggestions and help because I can not afford a F250.
Thank you
  • The scales don't lie!
    I had the same problem on a previous TC. I upgraded my rims and tires, Drove on the paved smooth highway and was ruthless in leaving 'gear' at home.
    Also it may not sit well with your insurers if you were in an incident and you were almost 1005 overloaded
  • If you are over manufacturer’s specs you are courting danger. Being “level” is great but you’re over by a bunch. Lighter camper.
