profdant139
May 10, 2013Explorer II
What brand is it? If you turned it on and turned it to gas, some models have no light showing at all unless it is NOT working, in which case the check light comes on. Also, make sure you have power to the fridge -- is your battery connected?
One way to check if the gas is working (and you don't want to wait for the fridge to cool down) is to remove the outside access panel and very carefully touch the burner area at the bottom of the compartment. You should feel heat.
44,056 PostsLatest Activity: Mar 02, 2026
