jaycocreek
Apr 28, 2020Explorer II
F-250 vs F-350 SRW..Basically little difference that matters with a truck camper as Burningman said..Same axles and same tires which are the most important thing with a truck camper IMHO...With either the F-250 or F-350 and a 4K truck camper..You will be modding it up for the sway a SRW has vs a DRW..
Both the F250 and the F350 are available with gas or diesel engines. Most are equipped with the diesel because it is more economical and hauls/tows better. Both the F250 and F350 are also available with both an automatic, and manual transmission. So what’s the drivetrain difference? There isn’t one. The F250 and F350 share the exact same drivetrain.
Depending on which year you Super Duty you’re looking at, the front axle may be a Dana 50 or Dana 60. Older F250s and F350s use the Dana 50, which is an excellent axle. Newer F250s and F350s use the Dana 60 which is slightly beefier than the Dana 50. All years of the SRW (Single Rear Wheel) F250 and F350 use the Ford/Sterling 10.75
All years of Super Duty trucks are available with heavy duty springs and standard springs. Both the F250 and the F350 have optional overload springs. The F350’s leaf springs are slightly stiffer, but it’s such a small difference you probably wouldn’t notice on the road. The F350 has stiffer springs up front as standard, the F250 has those same springs as an option. Something that surprised me is that both of these trucks come with factory blocks in the rear. The F250 is equipped with a 2.5? block, which lifts the rear up to help the truck sit level whilst towing. The F350 comes factory with a 4? rear block. The bigger rear block on the F350 gives it a slightly higher tow rating.
To put it simply, the F350 has marginally stiffer springs, and a 4? block compared to the F250’s 3.5? block.
Something I didn’t mention above is the fact that some states will consider the F350 to be a commercial vehicle. This will make your insurance and registration costs go up. If you live in a state where that is not the case, I would say get an F350. The slightly stiffer springs will make towing a little bit nicer. Prices for both the F250 and F350 are nearly identical, so there’s really no reason not to go with the F350.
