time2roll
Mar 28, 2013Nomad
mandygail wrote:
ok here is a picture - the mechanic said that this is only the second TT he has ever seen made this way - in other states it is legal, in MD it is not - it does appear to be very low to me - he said he is going to find out if a lift kit is allowed and if that would work - anyone have any thoughts??![]()
please let me know if you cannot see the picture - im new to the forum & need to figure out if it worked...[img][/img]
Probably a 4" drop axle. I think you could put a straight axle under it but you will lift the trailer (and u-bolts) 4" up if that is a big deal. Axle is not killer expensive especially if you can do the work yourself. Go to a suspension or trailer shop if considering a swap... not the inspection place.
http://www.al-kousa.com/pdf/T35_D35_2200-3500lb.pdf
44,068 PostsLatest Activity: Jun 10, 2026
