jbres
Mar 04, 2015Explorer
Thanks everyone for the replies so far.
Both rear windows just suddenly stopped working all together.
Burbman-thanks for the detailed message. Truck does not have power seats at all, if that helps.
I was looking over the fuses in my owners manual, and it appears the ones you talked about MBEC AND LBEC are separate, one for drivers and one for passengers. Is it possible that I could blow each of these separate at the same time to cause both rear windows to not work? Otherwise I was looking through the different fuse descriptions and the only others it seems it could be are CB RT DOOR AND CB LT DRS. both are rear power window fuses, but again could they both blow at once?
Thanks a lot for the advice so far!
44,052 PostsLatest Activity: Oct 29, 2025
