Cummins12V98
Aug 15, 2014Explorer III
If you want "SERVICE" then LS is the place for you. If you want quality parts and competent people working on your rig then I strongly advise looking elsewhere.
Example I just did a brake job on a truck I recently bought that LS did all the tires and brakes on. The grease seal was actually missing on one wheel.
Their shocks were so worn out you could take them and compress and pull apart with ease.
When you still have plenty of brake pad left and tell you you are in the unsafe zone and want to do a brake job.
I can go on for a long time with personal examples or first hand stories from family and friends.
RUN!!!!!!!!
Look at your tires that come from them most are made in China!
BTW I priced the Michelin MS2's from Discount for my dually then I figured Costco was going to be less, NOT! Discount was 2-$300 less I can't remember exactly but I was shocked. So be sure to check on Discount. They also give a Military discount.
RUN!!!!!!!!
44,059 PostsLatest Activity: Mar 18, 2026
