The saga continues..
When I left off yesterday, I was stumped on how to pull my old service panel with the valve cables. It turns out that this is very easy once you drop the eighth inch plywood bottom of the camper. There does not appear to be any caulking around these panels. I guess that it's just as well that they drain any water that might get in. This is a very easy job. There are about thirty small screws securing the ply to aluminum frame members. Once open, you can access the blade valves, an allen wrench and a phillips driver will disconnect the cable and housing so they may be pulled throught the service panel. I then reinforced the new panel with some aluminum angle stock and pop rivets. I was ready to finish the job and decided to check the welds on the frames supporting the fresh and black tanks. When I opened the bottom, part of the frame bracket fell out onto the ground - see photo. Two of the three verticle frame pieces in the front of the water tank had broken welds and were dangling uselessly. The horizontal frame members were all fine and looked like they had been machine welded, probably from a supplier. Their welds were perfect. The verticles were horrible spot welds. My camper is a 2005 which is the first or second year that Lance began using aluminum for frames. I hope that they have learned how to weld since then. There is no danger of the tank falling while the TC in on the truck, but pretty dicey off the truck. I can fix the one break with a screwed on plate, the other one is so hard to get to, I have not really figured out how to do it. I may just screw a metal strap to connect the top and bottom frame pieces.
I guess after all the years and miles, including lots of washboard and rough roads, this is to be expected, but the crappy spot welds are inexcusable from a company like Lance. I'll post some more pics of my fixes.
