Boatycall
May 12, 2020Explorer
Kayteg1 wrote:
Lithium batteries are often used in Sprinters conversions, where space and weight are at high premium, while money is no object.
First thing owners do is installing battery to battery chargers and lithium require higher voltage.
If your converter and solar module don't have adjustments, you will need to replace them.
I'm seriously considering these, because the built-in BMS makes them 'plug and play', directly replace lead acid deep cycle or AGM's, on ANY charger, even a cheap OEM Magna-junk.
Lion Energy Lithium Batteries
Quote from their website-- "The Safari UT 1200 is the latest in Lithium battery technology. It replaces traditional deep cycle lead acid batteries with the safest Lithium – Iron Phosphate. It is a “plug and play”– simply remove the deep cycle lead acid battery from your RV or boat and replace it with this superior performing battery."
