JIMNLIN
Oct 10, 2019Explorer III
OP...this comes up often when some one with a '00 to '06 1500HD asks about pulling a 5th wheel trailer or carrying a truck camper.
Some think the 1500 HD is a std duty 1500 truck which it ain't.
This is a paste and copy from a Silverado/Sierra forum for a bit of input on what your truck is...................
***The 1500HD was the old 2500 (non HD) replacment. At one time GM offered a 8600 lb 3/4 ton and a 9000 lb 1 ton single rear wheel truck. They came out with the 2500HD at 9200 lb and a 2500 at 8600 lb. The changed the 2500 to a 1500HD (I think it was so they could claim the highest towing capacity in the 1/2 ton market). When they brought out the 2500HD they dropped the 9000 lb 3500 single rear wheel truck.
The 1500HD was only available with a 6.0L but you could get 3.73 or 4.10 rears (the 2500HD was only offered with 4.10 ratio unless you got the 8.1 or the 6.6). The 2500HD was offered with the 6.0, the 8.1 or the 6.6 engines.
The 1500HD has a 4500 lb front axle and 4500 lb front suspension vrs the 4800 front axle and 4500 front suspension in the 2500HD.
The 1500HD has a 6000 lb rear axle and rear suspension vrs the 6900 rear axle and 6084 rear suspension on the 2500HD.
The 1500HD was only offered in a crew cab with a 6.5' box vrs a full line offering for the 2500HD.
The max payload of the 1500HD was 3129 lbs. vrs 3606 for a comparable 2500HD.
This info was found in the 2006 Chevrolet Truck Order Guide***
As some others have said GM gives these trucks a 6000 rawr. The truck rear axle may weigh in the 2700 lb range leaving approx 3000 lb in the bed payload. The truck sure won;t have any issues carrying a 3k load or stoping or moving it down the road.
You have a very popular truck with those that like and use them. Weigh the trucks front and rear axles that way you know how much real world payload you have to work with.
