Grit_dog
Oct 13, 2019Trailblazer
jaycocreek wrote:
That just shows the "lack of" knowledge of the camper dealers..Silicone gets the same bad rap on the internet as 1/2 ton trucks do, yet Bigfoot uses silicone on there campers as well as countless RV dealers for repair..
GM gives your HD 1500 a 6K rear axle rating, which is definitely more from the manufacturer of the axle as my Sterling(Ford) axle is...My F-350 DRW with a Lance 9.6 TC loaded ready to camp, weighs 6K even on the rear axle when I last weighed, out of curiosity..
Your not going to have any problems with a TC on your HD 1500 truck,within reason..Guys around here think an AF-811 is just fine on a 3/4 ton truck when it actually overloads a newer 3500 DRW in GVWR..Double standard..YES...
Your truck is a rare find, so enjoy it and don't listen to the nay sayers about 1/2 ton trucks,they are wrong about most of them but especially wrong about the HD version truck campers and towing with it
Enjoy just about any 8'6" TC on that truck.
Negative Jayco, you got yerself confused here.
A 9.5 sf axle is not "under rated at 6klbs." It's only marginally stronger than other sf axles. You're comparing your full floating axle and everything that goes with it to a legit heavy half type axle. Not a double standard. Rather a lack of understanding.
But this should serve to confuse the OP that much more. Hence my reccomendation in his cas e to find a real 3/4 ton truck.
"I " would put 3k on that truck, but I wouldn't want to as better options for basically the same $ are readily available when the setup is marginal to begin with.
