JrStaffordExplorerAug 11, 2020Need help with Dometic Duo Therm Air ConditionerJust picked up a really nice 2000 Lance Lite. Slight issue with the AC, it works TOO GOOD! It will absolutely freeze you out, and after it runs for a couple of hours, it will start slowing down to t...Show More
toddbExplorerAug 12, 2020If it ices over before it reaches the set point of the thermostat it's most likely low on refrigerant.
Related ContentAir Conditioner vibrationDometic duo therm fan issueDometic Duo Therm AC issueDometic Duo Therm Air Conditioner--does it blow in debris?Air conditioner dripping inside (Dometic)
