mkirsch
Aug 13, 2020Nomad II
JrStafford wrote:
It's definitely working, I can change the 'colder' knob, and you can feel it click and cut the AC to just air. I'll experiment tomorrow, hoping that if I don't have the cold as far as it will go on 'colder', the AC will cycle on and off as it should. I've just always ran a camper AC as cold as it will go, all the time. Maybe I can't do that with this one? I don't think I've ever seen a camper AC run as cold as this one.
If it's still showing ice on the lines and compressor, then the one poster above is probably correct....It's low on refrigerant and probably will take a dump on me.
If the AC can NOT keep the camper at the desired temperature without running all the time, there is something wrong. The temperature outside is too extremely hot, the AC unit is undersized, or the AC unit is faulty.
The way your current AC is working is how it's SUPPOSED to work. You're supposed to be able to set the temperature and have the AC unit cycle on and off.
