westend
Apr 28, 2015Explorer
Your old converter is basically just a power supply. A more modern converter would have three or so stages of output to enable battery charging. The power supply I linked to will make cleaner (in the electronic sense) than a typical converter. The Meanwell power supply delivers the same voltage as your old converter so would run all of your 12V devices (heater, lights, etc.).
I'd assume that your rig is pretty old since that converter hasn't been sold for years. You may have had only a small fuse board containing two or three fuses. My older Starcraft was similar.
I mentioned the Meanwell power supply since it is a known good quality, fits your power requirements, and would save some money vs. a converter.
For the amount of power you require for your 12V devices, a large computer supply would be close to delivering what you need.
44,066 PostsLatest Activity: Mar 14, 2015
