bartandcathy's avatar
bartandcathy
need help with truck ratings
I have a truck (new to me) details follow:
1984 GMC 1500
4 x 4
Diesel engine
8 foot bed
2 person cab
Vin # is 1GTEK14S3RE559687
A sticker inside the glove box has information about truck camper loading, and states the following:
Cargo weight rating 516lb/234Kg
Sticker in the door jamb states:
GVWR 6100/2767
GAWR FRT 3880/1760
GAWR RR 3750/1701
Rims 17 x 7.6 front and rear
Tires LT225/75R16C @ 50psi
If I understand this info correctly, the vehicle must weigh 5584lbs as is, and the heaviest camper I can use with this set up would be 516lb. (about 1,000lb less than the 'light' campers I have seen).
So, my questions ...
If that is so, then do I have any options to increase that weight loading?
I am thinking upgraded springs? Air bags (not sure what they are)? Alternative tires with a shallower sidewall? (for better handling)
Or should I find a good valet and get it ready to sell?
I truly appreciate in advance the efforts anyone puts into guiding me.
Kind Regards,
Bart Robinson
