Heavy_Metal_Doc
May 02, 2014Explorer
Brett K wrote:
I need a bit more length on the safety chains on my hitch. I found some links with the nut that closes over the opening at Tractor Supply rated at 3500 lbs. it looks thicker than my chain links. The wet weight on my trailer is about 7000. Is this a safe fix?
They will be fine. Being safe is one thing, but you don't need to go overboard. You are not going to lift the 7000lb trailer off the ground by one of those rings, you just need to maintain a connection between the tow vehicle and the trailer in case of a coupler failure / separation. If you have a hard enough jerk to yank one of the 3500LB links apart, then you will likely either rip the chain off the trailer frame (3/16" steel tubing trailer frame is not that strong), or pull the safety loop off the receiver hitch of your TV. Keep in mind most parts like these screw links have a working rating stamped on them and the test "burst" strength is much higher - on many parts that rating 2 1/2 times the rated number.
44,056 PostsLatest Activity: Nov 19, 2013
