BradW wrote:
twodownzero wrote:
 From reading on here, it seems that the shock manufacturers have a marketing problem.  Rancho's RS9000 is a popular shock for many applications and its dial isn't a solution for properly sized and valved shocks for the application.
The problem is, there is no magical "properly sized and valved shocks for the application".  That is because there is not one application, there are two very different applications because the weight on the rear axle changes 4,000 to 5,000 lbs depending on whether the camper is loaded on the truck or not.  That's why there is a knob to adjust the shock valving based on the weight it is dampening.
Brad
I don't think that's quite right, but again, I am far from an expert.  The weight that is on the axle should be related to the size of the shock, and thus the amount of heat that has to be dissipated, but the valving has more to do with the type of suspension and how it cycles, not the amount it deflects (which is related to weight).
Stiffening the shocks because more weight is on the truck isn't asking the shocks to "control" motion, it is seeking to increase the spring rate to reduce deflection.  Such movement is better controlled by the proper spring rate and a sway bar to control excess articulation, not shock absorbers.
Stiffer shock valving might be a mask (and perhaps the best available mask) for an overloaded suspension system.  I really don't know the answer to that but I am happy with my air bags as to supporting the additional weight.
The companies I had in mind would be the ones famous for off-road related shocks: Bilstein (for both OEM mounts and for those willing to rework the mounting) and Fox/King/Sway-a-way (which would be more high performance shocks designed for those willing to make more extensive modification).  I am absolutely certain that those who sell the latter products would be able to point you toward something that may work for your truck.  They won't be cheap, but if a monster truck can have a controlled ride, so can our trucks with the camper on.
