txmerlin
Jun 28, 2019Explorer
Need new tires
Need to replace the 5 year old tires on my TT and need some advice about upgrading. The trailer is 38 feet and has a GVWR of #9975 and currently has Load Range D tires from the trailer manufacturer. ...
DownTheAvenue wrote:BurbMan wrote:
I converted my 15" STs to 16" LTs a while back, and that involved putting a 2" lift onto the suspension. I bought a set of LT rims and E rated tires from a guy who said that even though the rims were stamped "65 psi max" he ran them at 80 psi no problem.
The clearcoat is peeling off these rims and they look awful, so this time around I bought new wheels and the PSI rating says "Limited to valve stem". The weight rating is more than enough to handle an E tire, and the valve stem for the TPMS I use is rated at 100 psi.
Here is the same rim in a 15" that says the same for PSI rating. If you don't want to go to LTs, then I would upgrade the rims and get the best E-rated ST tire you can find.
This is the best advice. Upgrade to 16" wheels and put on "LT" tires and never again worry about your trailer tires.
